If you're running a CPR Stage 1 engine, you'll be one of the lucky group of succesful karters. Built tough and reliable with performance as number 1 prioirity, the Stage 1 engine is the perfect engine when you're running within a stock 200cc class.
We're sure your thrilled with the performance and reliablity of your new engine (and we're told this every day by customers with the widest grins). Our technical engine specialist has created this list of checks & maintenance schedule to keep your engine running in tip top condition for loads of races.
1. Things to check / tighten regularly
2. Service intervals
- Every x hours/races change oil, oil filter etc.
- Every x hours check clearances
- Every x hours replace spark plug
- Every x hours check and clean carburettor
etc
