B:
Home :: GUIDE - #35 Sprocket Sizing and Gearing
GUIDE - PROJECT GEARING SELECTION
GEARING UP
#35 Gearing Explained
INTRODUCTION - About this guide
When customers choose #35 pitch gearing (which we highly recommend for projects due to the 2-piece split sprockets and removable link chains – see our chain guide for more information) I am often asked the question “What is the inside diameter of your split sprocket?” and “What is the outside diameter of an x tooth sprocket” so I’ve decided to write this informative but straight-forward guide focussed on explaining what needs to be done to fit our standard race kart sprockets and gearing your project.
Generally, when gearing your project, you have 3 problems to overcome.
1.       Fitting the sprocket to your axle
2.       Ensuring the overall sprocket size does not foul on the ground or chassis
3.       Selecting a practical starting gear ratio
This guide will run you through the decision making process as well as provide technical details on the products so that you can decide if #35 race kart gearing is suitable for your project.  I’ll run through these three sections quickly but informatively in the hope I don’t bore you, but that you have easy access to the information needed to get it right the first time.
PART 1 - Fitting the sprocket to your axle
Our #35 sprockets are a split sprocket which is ideal in situations where the sprocket is driven ‘inboard’ on the axle (ie: between the axle bearings).   They are easy to remove and install making gearing a breeze to get correct, or to change out a worn sprocket.
You can find our full range here: http://www.cutpriceracing.com.au/store/home.php?cat=351
The centre bore size A is 116mm.
The PCD Diameter(B) is (6x) 132mm (centre of 6mm holes on opposite sides of sprocket)
All standard race-kart sprocket hubs will accept our sprockets.  We can supply sprocket hubs to fit most metric shaft sizes – 25mm, 30mm, 35mm, 40mm.
You can find sprocket hubs to suit here (Click your axle size and keyway width to find your hub):
25mm/6mm, 30mm/6mm, 30mm/8mm, 35mm/6mm, 35mm/8mm, 40mm/8mm
The hubs will accept the sprocket perfectly.  All you need to do is slide it onto your shaft.  Select the correct size shaft version of the sprocket.  If you have an imperial size shaft, we cannot offer a solution, but some people have successfully adapted the metric hubs to an imperial shaft.
PART 2 – Ensuring the overall sprocket size does not foul on the ground or chassis
Your new #35 sprocket will differ in sizing depending on the number of teeth you have chosen.  Circumference will determine the number of teeth you will have.  The reason the size differs is because the pitch of the chain determines the length required for one full link or tooth.
For those uninterested in the math, please skip this paragraph.  #35 pitch is 9.525mm, so for every tooth, the circumference must be increased by 9.525mm.  In addition, the height of each tooth is about 5mm so we need to add approximately 2.5mm extra from the centreline of each tooth (or approximately 5mm to the diameter)   This means we have a formula #TEETH x 9.525mm = Pi x Diameter.  Or we could write it as #teeth x 9.525mm divided by Pi = Diameter plus 5mm.  Translating back to diameter, our smallest sprocket (53T) has a diameter of   53 x 9.525 / Pi (3.141592) = 166mm.
Your chain will sit around 3mm proud of the tip of each tooth, so you’ll need to add approximately 6mm to the diameter of the sprocket to get the correct clearance amount.
Here’s a table of diameters:
#Teeth
Dia mm
Dia w/chain mm
53
166
172
54
169
175
55
172
178
56
175
181
57
178
184
58
181
187
59
184
190
60
187
193
61
190
196
62
193
199
63
196
202
64
199
205
65
202
208
66
205
211
67
208
214
68
211
217
69
214
220
70
217
223
71
220
226
72
223
229
73
226
232
74
229
235
75
232
238
76
235
241
77
238
244
78
241
247
79
244
250
80
247
253
81
250
256
82
253
259
83
256
262
84
259
265
85
262
268
PART 3 – Selecting a practical gear ratio
Once you’ve determined your limitations in relation to ground and chassis clearances, the next step is to determine the best gear ratio.  There are several things to consider, including:
-          Desired Acceleration
-          Desired Top Speed
-          Minimum operating speed
o   One of the most important considerations is the minimum ‘fully engaged’ clutch speed.  Most stock clutches engage around 2000rpm.  With a governed 4-stroke engine, that means you have a working range of somewhere between 2000 and 3500rpm.  If you select too tall gearing, and you constantly operate the kart at speeds which bring the motor close to or below the 2000rpm engagement point, you will encounter clutch problems as the clutch is continually slipping.
The following table gives approximate speeds for gearing.  It is recommended not to use gearing in the orange sections, and red sections will almost certainly result in mechanical failure.
 Tall gearing (lower ratios) may struggle to gain rpm if the power of the engine is not enough to overcome the torque of the axle.  This is more pronounced the larger the wheels are, so bear this in mind.
What if I have very large wheels in excess of 400mm and still can't get a short enough ratio for the ratio needed?
It's ok, don't panic - there are a couple of options - you can consider a Torque Converter (CLICK HERE TO READ ABOUT TORQUE CONVERTERS) and in addition we've got a brand new 2:1 reduction kit available in stock to suit #35 sprockets (there's one due for 420P shortly too!) so you can run up to 800mm rear wheels and tyres!  Awesome right?  This little kt goes in-line between your torque converter or dry clutch to reduce the ratio by another 2 times - meaning you can run about a 6:1 reduction using a torque converter, allowing for the use of really big wheels.  CLICK HERE TO FIND OUR 2:1 REDUCTION KITS
Always select the shortest gearing (highest ratio) first and work your way down with rear sprocket sizing to ensure you do not damage your clutch and that you can ensure your project will get mobile initially.
Senior rear rims & slicks 11x7.10-5 265mm dia 832.52
Sprocket Sprocket Final 2000 3500 7000
Clutch Rear Ratio Min Max Max
12 53 4.42 23 40 79
12 54 4.50 22 39 78
12 55 4.58 22 38 76
12 56 4.67 21 37 75
12 57 4.75 21 37 74
12 58 4.83 21 36 72
12 59 4.92 20 36 71
12 60 5.00 20 35 70
12 61 5.08 20 34 69
12 62 5.17 19 34 68
12 63 5.25 19 33 67
12 64 5.33 19 33 66
12 65 5.42 18 32 65
12 66 5.50 18 32 64
12 67 5.58 18 31 63
12 68 5.67 18 31 62
12 69 5.75 17 30 61
12 70 5.83 17 30 60
12 71 5.92 17 30 59
12 72 6.00 17 29 58
12 73 6.08 16 29 57
12 74 6.17 16 28 57
12 75 6.25 16 28 56
12 76 6.33 16 28 55
12 77 6.42 16 27 54
12 78 6.50 15 27 54
12 79 6.58 15 27 53
12 80 6.67 15 26 52
12 81 6.75 15 26 52
12 82 6.83 15 26 51
12 83 6.92 14 25 51
12 84 7.00 14 25 50
12 85 7.08 14 25 49
13 53 4.08 25 43 86
13 54 4.15 24 42 84
13 55 4.23 24 41 83
13 56 4.31 23 41 81
13 57 4.38 23 40 80
13 58 4.46 22 39 78
13 59 4.54 22 39 77
13 60 4.62 22 38 76
13 61 4.69 21 37 75
13 62 4.77 21 37 73
13 63 4.85 21 36 72
13 64 4.92 20 36 71
13 65 5.00 20 35 70
13 66 5.08 20 34 69
13 67 5.15 19 34 68
13 68 5.23 19 33 67
13 69 5.31 19 33 66
13 70 5.38 19 32 65
13 71 5.46 18 32 64
13 72 5.54 18 32 63
13 73 5.62 18 31 62
13 74 5.69 18 31 61
13 75 5.77 17 30 61
13 76 5.85 17 30 60
13 77 5.92 17 30 59
13 78 6.00 17 29 58
13 79 6.08 16 29 58
13 80 6.15 16 28 57
13 81 6.23 16 28 56
13 82 6.31 16 28 55
13 83 6.38 16 27 55
13 84 6.46 15 27 54
13 85 6.54 15 27 53
18 53 2.94 34 59 119
18 54 3.00 33 58 117
18 55 3.06 33 57 114
18 56 3.11 32 56 112
18 57 3.17 32 55 110
18 58 3.22 31 54 109
18 59 3.28 30 53 107
18 60 3.33 30 52 105
18 61 3.39 29 52 103
18 62 3.44 29 51 102
18 63 3.50 29 50 100
18 64 3.56 28 49 98
18 65 3.61 28 48 97
18 66 3.67 27 48 95
18 67 3.72 27 47 94
18 68 3.78 26 46 93
18 69 3.83 26 46 91
18 70 3.89 26 45 90
18 71 3.94 25 44 89
18 72 4.00 25 44 87
18 73 4.06 25 43 86
18 74 4.11 24 43 85
18 75 4.17 24 42 84
18 76 4.22 24 41 83
18 77 4.28 23 41 82
18 78 4.33 23 40 81
18 79 4.39 23 40 80
18 80 4.44 22 39 79
18 81 4.50 22 39 78
18 82 4.56 22 38 77
18 83 4.61 22 38 76
18 84 4.67 21 37 75
18 85 4.72 21 37 74
Not Recommended
(either gearing too tall, or sprocket diameter too close to ground)
Certain damage to drivetrain (too tall gearing or sprocket fouls)
13" Off-Road wheels 13x5.00-6 290mm dia 911.06
12 53 4.42 25 43 87
12 54 4.50 24 43 85
12 55 4.58 24 42 83
12 56 4.67 23 41 82
12 57 4.75 23 40 81
12 58 4.83 23 40 79
12 59 4.92 22 39 78
12 60 5.00 22 38 77
12 61 5.08 22 38 75
12 62 5.17 21 37 74
12 63 5.25 21 36 73
12 64 5.33 20 36 72
12 65 5.42 20 35 71
12 66 5.50 20 35 70
12 67 5.58 20 34 69
12 68 5.67 19 34 68
12 69 5.75 19 33 67
12 70 5.83 19 33 66
12 71 5.92 18 32 65
12 72 6.00 18 32 64
12 73 6.08 18 31 63
12 74 6.17 18 31 62
12 75 6.25 17 31 61
12 76 6.33 17 30 60
12 77 6.42 17 30 60
12 78 6.50 17 29 59
12 79 6.58 17 29 58
12 80 6.67 16 29 57
12 81 6.75 16 28 57
12 82 6.83 16 28 56
12 83 6.92 16 28 55
12 84 7.00 16 27 55
12 85 7.08 15 27 54
13 53 4.08 27 47 94
13 54 4.15 26 46 92
13 55 4.23 26 45 90
13 56 4.31 25 44 89
13 57 4.38 25 44 87
13 58 4.46 25 43 86
13 59 4.54 24 42 84
13 60 4.62 24 41 83
13 61 4.69 23 41 82
13 62 4.77 23 40 80
13 63 4.85 23 39 79
13 64 4.92 22 39 78
13 65 5.00 22 38 77
13 66 5.08 22 38 75
13 67 5.15 21 37 74
13 68 5.23 21 37 73
13 69 5.31 21 36 72
13 70 5.38 20 36 71
13 71 5.46 20 35 70
13 72 5.54 20 35 69
13 73 5.62 19 34 68
13 74 5.69 19 34 67
13 75 5.77 19 33 66
13 76 5.85 19 33 65
13 77 5.92 18 32 65
13 78 6.00 18 32 64
13 79 6.08 18 31 63
13 80 6.15 18 31 62
13 81 6.23 18 31 61
13 82 6.31 17 30 61
13 83 6.38 17 30 60
13 84 6.46 17 30 59
13 85 6.54 17 29 59
18 53 2.94 37 65 130
18 54 3.00 36 64 128
18 55 3.06 36 63 125
18 56 3.11 35 61 123
18 57 3.17 35 60 121
18 58 3.22 34 59 119
18 59 3.28 33 58 117
18 60 3.33 33 57 115
18 61 3.39 32 56 113
18 62 3.44 32 56 111
18 63 3.50 31 55 109
18 64 3.56 31 54 108
18 65 3.61 30 53 106
18 66 3.67 30 52 104
18 67 3.72 29 51 103
18 68 3.78 29 51 101
18 69 3.83 29 50 100
18 70 3.89 28 49 98
18 71 3.94 28 49 97
18 72 4.00 27 48 96
18 73 4.06 27 47 94
18 74 4.11 27 47 93
18 75 4.17 26 46 92
18 76 4.22 26 45 91
18 77 4.28 26 45 89
18 78 4.33 25 44 88
18 79 4.39 25 44 87
18 80 4.44 25 43 86
18 81 4.50 24 43 85
18 82 4.56 24 42 84
18 83 4.61 24 41 83
18 84 4.67 23 41 82
18 85 4.72 23 41 81
